I have some components that are to be installed only when a property has been set by the AppSearch action.
When doing a clean install, the components are installed without problems. But when I run the installer in maintenance mode to add features, the same components taht are installed correctly by qa clean install doesn't get installed when runiing in maintenance mode.
I see in the log that the property is set correctly so I would expect the condition to be evaluated correctly as well.
P.S.: I've already set the component transitive.
Jacques.
Component condition based on app search
BourqueJ
, Oct 18 2007 18:48
Posted 18 October 2007 - 19:55
Does the log give any clues?
