I want to dynamically change the [INSTALLDIR] property. We have 2 different type of products, "ProductType1" and "ProductType2". 95% of the components are same for both the product types. Only 5% of the components differ based on the product type.
I created 2 features for each product type. I then associated the common components to both the features and then the differing components seperately to their corresponding product type features. Now the problem is, I need to have the install directory based on the feature selected at run time.
ie
for ProductType1 the install directory should be
"[ProgramFilesFolder]\CompanyName\ProductType1" &
for ProductType2 the install directory should be
"[ProgramFilesFolder]\CompanyName\ProductType2"
I want to acheive it by not having to duplicating the 95% common components. Also i need to write the Final Install Directory into the registry too..
Any help would be greatly appritiated.
thanks & regards,
Jayashree
Need urgent help on Dynamic INSTALL DIR
Jayag
, Mar 24 2006 01:06
Posted 24 March 2006 - 11:08
You will need somenthing on the lines of:
// Determine the installed state of FeatureProduct1.
nResult = FeatureIsItemSelected (MEDIA, "eatureProduct1");
szCommonPathPart=PROGRAMFILES^"CompanyName";
if nResult = 1
then
FeatureSetTargetMEDIA, "<INSTALLDIR>",
szCommonPathPart^"ProductType1");
else
szCommonPathPart^"ProductType2");
if nResult = 1
then
else
Posted 26 March 2006 - 17:11
Hi all,
Thanks for the immediate response. But FeatureIsItemSelected method is NOT working for me. Even though i select a particular feature from the AskOptions dialog, it always returns an error -105 (which is Specified feature cannot be found in the media). . The below code snippet is how i tried to use the FeatureIsItemSelected method. can you please tell me what mistake i am doing.
nResult = SdAskOptions ("Product Selection", "Select the product to install.",
"", "", "DefaultFeature",
EXCLUSIVE);
if (nResult = BACK) goto Dlg_SdCustomerInformation;
szInstallDirPath = "";
szInstallDirPath = INSTALLDIR;
nRes = FeatureIsItemSelected(MEDIA, "Prod1");
if nRes = 1 then
szInstallDirPath = szInstallDirPath^"Prod1";
else
szInstallDirPath = szInstallDirPath^"Prod2";
endif;
FeatureSetTarget(MEDIA, "<INSTALLDIR>", szInstallDirPath);
I also tried to use "FeatureGetData", but it also returns false everytime.
thanks & regards,
Jayag
EXCLUSIVE);
if nRes = 1 then
else
endif;
thanks & regards,
Jayag
Edited by Jayag, 27 March 2006 - 00:59.
Posted 27 March 2006 - 01:20
Hi All,
I found the problem with my code. Actually i had the Prod1 under DefayltFeature. So i had to use
nRes = FeatureIsItemSelected(MEDIA, "DefaultFeature\\Prod1");
instead of
thanks & regards,
Jayashree
instead of
thanks & regards,
Jayashree
