I just created a simple setup file with a vbscript in custom action to set the REINSTALLMODE property. The VBscrpt looks like this:
'Setting a Property
Sub SetAProperty_a
Session.Property("REINSTALLMODE")="amus"
End Sub
'Getting a Property
Sub GetAProperty_a
dim getStringVal
getStringVal= Session.Property("REINSTALLMODE")
End Sub
And everytime when I run the setup, a "files in use" box pop up and it requires me to close all the opening applications/programs(like NotePad, internet Explorer, Microsoft outlook etc) because it said it has to update some files....
However, If I don't include that VBscript in the custom action and run the setup, It doesn't ask me to close all applications.
OK. Here is my question:
Does anyone know what files do they want to update? I just set the property of REINSTALLMODE, how come they need to update a file?
Also, is there a way to bypass the "Files in Use"?
Thanks.
InstallShield Express 5
TPhan
, Nov 19 2004 16:52
Posted 20 November 2004 - 17:48
"a" means "overwrite all files, regardless of version". This also applies to system files that you may be installing, and thet may be in use by notepad etc. "a" is a very dangerous setting as it could cause a downgrade of system files, thus damaging the operating system. It should be avoided.
