Hi.. i'm trying to uninstall previous version of the application and install
to a new version. This is the code i wrote.
Somehow the compile doesn't go through "LaunchAppAndWait" part,
i have no idea what i did wrong. Please help me~
#include "ifx.h"
#define EXAMPATH WINDIR ^ "C:\\Program Files\\KrCon\\KRCON2004.EXE"
#define SOURCE_VER "5.10.0000"
// OnFirstUIBefore
// The OnFirstUIBefore event is called by the framework when the setup is
// running in first install mode. By default this event displays UI allowing
// the end user to specify installation parameters.
function OnFirstUIBefore()
NUMBER nResult, nSetupType, nvSize, nUser;
STRING szTitle, szMsg, szQuestion, svName, svCompany, szFile;
STRING szLicenseFile, szDir, svVersionNumber, svVersionNumber1;
LIST list, listStartCopy;
BOOL bCustom;
begin
TARGETDIR = "C:\\Program Files\\KRCON2005";
// TO DO: if you want to enable background, window title, and caption bar title
// SetTitle( @PRODUCT_NAME, 24, WHITE );
// SetTitle( @PRODUCT_NAME, 0, BACKGROUNDCAPTION );
// Enable( FULLWINDOWMODE );
// Enable( BACKGROUND );
// SetColor(BACKGROUND,RGB (0, 128, 128));
SHELL_OBJECT_FOLDER = @PRODUCT_NAME;
szDir = INSTALLDIR;
svName = "";
svCompany = "";
//find out whether the old version is installed or not
svVersionNumber = SOURCE_VER;
VerGetFileVersion(EXAMPATH, svVersionNumber1);
nResult = VerCompare(svVersionNumber, svVersionNumber1, VERSION);
MessageBox("Uninstalling Krcon 2004", MB_OK);
if(svVersionNumber1 != "") then //it has been installed already
LaunchAppAndWait("C:\\windows\\system32\\Msiexec.exe/X{4B3903E3-3D4E-4FAA-94F9-D94D41225E92} ","",WAIT);
endif;
what is wrong with my code for uninstalling...
sean394
, Jun 17 2005 16:00
Posted 20 June 2005 - 14:14
Take a closer look at the help for LaunchAppAndWait. The first parameter is the fully-qualified path to the executable and the second parameter is the command line for the executable. So your code should read:
LaunchAppAndWait("C:\\windows\\system32\\Msiexec.exe ", "/X{4B3903E3-3D4E-4FAA-94F9-D94D41225E92} ", WAIT);
Hope this helps.
Hope this helps.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
