I met some problem converting my project from IPWI2.03 to Dev7, recently I did a fresh install of w2k OS on the test machine, some of the problems have been gone, but I still have problem on major upgrade:
first time install always works, but when I install a new package (same Upgrade code) on top of it (do major upgrade), the install is stuck. The log file shows error 1618, which says there is another installation in progress... I do see a msiexe.exe process at taskmgr after first install (which I think is incorrect), but can't kill the msiexec.exe using 'End task' in taskmgr, and have to reboot machine. After reboot, the msiexec.exe is gone, but install is still stuck.
I just read a post in installshield.developer7.general (post title "Re: 'Major upgrade' from ISPro 6.12 script"), it says that major upgrade doesn't work on Dev7, is that true? If it is, do you plan to fix it in the future?
