Using IS Dev 7 (is this the wrong forum for that?) ...
Setting a condition on a component using a "user" defined
property - can this be done? If so, what is the correct
syntax?
By "user defined property" I mean one I created via the
property manager. Note that property I trying to use is
a "localizable" property. (Don't know if that adds a problem
to this).
-Arthor
arthor@mathsoft.com
Install Conditions (Via Dev 7)
arthorw
, Mar 04 2002 16:40
Posted 04 March 2002 - 22:57
As long as the property value is set before the CostFinalize action this should work.
P.S. correct forum
P.S. correct forum
