I want to remove old registry entries which were added by older releases.
Let me explain my issue with example.
There was one build say 1 in which there was a registry entry "[HKEY_LOCAL_MACHINE\SOFTWARE\ABC\{99C41FDE-98E8-4608-8ECC-BE1940916AA7}]" in component say "Component1"..
A patch was created say 2 and under that patch the value of registry in"Component1". was changed to "[HKEY_LOCAL_MACHINE\SOFTWARE\XYZ\{99C41FDE-98E8-4608-8ECC-BE1940916AA7}]"
Now we have created a major upgrade say 3 and have removed "Component1" and hence the whole registry entry.
There is no registry entries if we install 3 .
However if we upgrade 1->2->3 and then uninstall the whole build the registry entries which were created while installing 1 still remains.
Do I have to write a script to remove this registry entry.(I tried using RemoveRegistry table but nothing worked).
Alex
How to remove old registry entries.
AlexLX
, Mar 20 2012 08:16
Posted 22 March 2012 - 11:40
Your change from version 1 to version 2 orphaned the ABC entry. I think it would have been best to use RemoveRegistry in version 2.
BTW: the registry entry isn't the key path of the component I hope.
But RemoveRegistry should work even in version 3 if it is populated properly. Plase post your settings.
Posted 29 March 2012 - 08:01
Hi Stefan,
Sorry for the late reply.
Following are the settings that I used in RemoveRegistry after deleting NewComponent1 from Version 3(which is a major upgrade)
RemoveRegistry: HKEY_LOCAL_MACHINE
Root: 2
Key: SOFTWARE\ABC\{<CLSID value>}
Component: NewComponent1
Note:
NewComponent1 was the component which was having the registry file in version 1 and version 2 and which was removed in version 3.
So in minor upgrade even if we modify the component value(without deleting them), it will make the original value orphaned?
what should have i done in version 2: Created a new component to have the new registry entry and removed the registry entry in NewComponent1 or should I have used RemoveRegistry
Root: 2
Note:
Posted 29 March 2012 - 20:05
| Note: NewComponent1 was the component which was having the registry file in version 1 and version 2 and which was removed in version 3. |
I guess that's the problem. The RemoveRegistry will delete the entry, if the specified component get *installed*, so you need to specify some component here that is actually being installed.
| So in minor upgrade even if we modify the component value(without deleting them), it will make the original value orphaned? |
Modifying the value shouldn't be a problem, but changing the name or the key is a problem.
If you had removed the old registry entry from the component this wouldn't have removed it. Components should be treated as atoms - don't split them or remove parts of it. If you must, use the RemoveRegistry table.
Posted 30 March 2012 - 05:56
I thought under Component i should put the name of the component which was having the registry entry(which was eventually removed in version 3).
Thanks for clearing my doubt.
