Our install is maed from .rul files into our package using IS3.01
I have to install our software on an Intanium PC running Windows XP Advanced Server (64-bit). This OS dosnt support 16-bit software, so I'm stuck!
Really need help with this one!!!
Posted 25 September 2001 - 07:22
Posted 25 September 2001 - 12:20
Posted 26 September 2001 - 00:50
For example:
With IS 3.0 we use compile.exe with our *.rul files to make the setup.ins file. We then use icomp.exe to make our data.z file. We then simply copy over the re-distributable files and that’s it!
Is there a way a package can be made this simply with IS6 or Dev7?
Posted 26 September 2001 - 08:25
ISD7 is the only InstallShield version with specific support for 64 bit Windows, so if your application (or parts of it) is 64 bit, or you're planning to go that route, ISD7 is the tool to use.
