We are wraping our .Msi packages inside Microsoft's SMS for distributing to our clients. My problem is that I need to change the Installer package's UninstallString to call SMS's uninstall string. Changing the \uninstall\ProductCode\UninstallString does nothing. I can set \uninstall\ProductCode\WindowsInstaller=0 and it will work; BUT there are now two product entries in the ARP. What is the correct way to change the UninstallString?
Uninstallations
Cygnusx1
, Jun 26 2001 19:40
Posted 23 July 2002 - 22:19
Dude you're doing this WAY the hard way (but don't worry, we used to do the exact same thing.)
Scrap the EXE wrapper, you don't need it. Instead, create a package in SMS Admin and on the Reporting tab of the package properties, add a MIF filename (do not add the .mif extension.) Then, setup a program for the package with the following command line:
msiexec /i "\\server\path\appname.msi" /m "mifname" /qn ALLUSERS="1" REBOOT="ReallySuppress"
Again, don't add a .mif extension. Be sure to have SMS reboot the computer, not the package (if reboots are necessary.)
Then, when you need to uninstall something, you just advertise a new package with the command line:
msiexec /x {packagecode}
Makes life SO much easier. :) Take that SMS Installer and throw it in the trash. There's a TechNet whitepaper titled "Deploying Windows Installer Setup Packages with Systems Managements Server 2.0", check it out for more info about this stuff.
