Hallo!
Does someone know, if we have to add the "Shield icon" to the install button in the ReadyToInstall dialog?
And if, how to?
Thanks in advance!
Johannes
Install button and UAC
Johannes John
, Apr 11 2007 15:58
8 replies to this topic
Posted 11 April 2007 - 16:55
Hello!
Does someone can confirm my suggestion of a solution:
Add 8388608 (0x00800000, msidbControlAttributesElevationShield ) to the attribut of the button in the control table?
Suggested dialogs and buttons:
ReadyToInstall; InstallNow
ReadyToRemove; RemoveNow
Thanks for any confirmation!
Johannes
Johannes
Posted 13 April 2007 - 15:00
If your setup requires elevated rights and thus will trigger the UAC dialog, then you should add the shield icon.
I haven't looked at the exect values but msidbControlAttributesElevationShield looks promising.
Posted 10 May 2007 - 10:26
Hello,
there's a further dialog:
AdminNetworkLocation with the InstallNow button.
During the Administrative Installation, the admin account seams to be required too.
Regards!
Johannes
Regards!
Johannes
Posted 11 May 2007 - 17:02
What about Change and Repair buttons?
More importantly, when I add this attribute, I never see the shield... nor does the act of clicking the button give a UAC prompt. What do I need to add to convince the installer that elevation will be needed on the button press?
Many thanks,
Gareth
Many thanks,
Gareth
Posted 14 May 2007 - 12:18
Hello Gareth,
to get the UAC prompt,
start a WI-Setup on VISTA at a standard user, not the admin nor a user of the admin group. You get the UAC prompt, when the InstallFinalize will be started.
I'm going to check the maintenance dialogs.
Johannes
Johannes
Posted 14 May 2007 - 16:23
Thanks for your 'non-administrator' pointer Johannes - I now see the shield. But, I really want it to appear for Repair, Remove and the Administrator (who doesn't have the priveledges until the Install button is clicked and the UAC prompt comes up) accounts.
I really am beginning to think that there's a huge bug in all this MS technology somewhere... my installs can be uninstalled by locked-down users with no UAC prompt at the moment!! I can't think of a better way to really annoy network administrators.
Regards,
Gareth
Regards,
Gareth
Posted 14 May 2007 - 16:58
Hello Gereth,
have a look at:
http://technet.micro...a/aa905108.aspx
Regards,
Johannes
P.S. The admin doesn't needs the shield, because he has the wright to get the elevation, whenever he wants.
have a look at:
Regards,
Johannes
Posted 18 May 2007 - 08:45
Hello!
To: "What about Change and Repair buttons?"
These two buttons in the "MaintenaceType" dialog lead at the end to the "ReadyToInstall" dialog.
The Remove button in the "MaintenaceType" dialog leads to the "ReadyToRemove" dialog.
But I myself don't get the shield on the "Remove" button in the "ReadyToRemove" dialog!
Does someone has an explanation?
Is there a bug or do we/I have to do more?
Thanks in advance!
Johannes
Thanks in advance!
Johannes
