Hi, has anyone encouter this problem before?? If you do, then how do you solve this problem??
The situation is this, I am creating msi packetages for couple programs, and I want them to be installed on the All User instead of just one specify user. However, when I do change the Installation on All User, and then log on to through network. The packages won't install and gives me the error. But however, when I log in locally on the machine, and install it. It works okay.
Please help me. Thank you.
Error: 1327 Invalid Drive L:\
mobile_suit_zero
, Nov 29 2002 22:56
Posted 30 November 2002 - 09:16
Are you installing with elevated privileges? In this case your setup runs in system account, which may not have access to all network locations.
Posted 06 January 2003 - 10:44
Do you have a drive L: created within your property table. If so, do you have a drive L: mapped when installing the MSI. I had a similar problem where we wanted to add files to a user's home directory and to do this we created a property called USERHOME and issued it a value of H:\.
This worked fine for that particular package, so we decided to add it to the template. However, on subsiquent packages where the H: drive was not mapped during installation, we had the same error you had and so removed it from the template posthaste.
Posted 07 January 2003 - 10:24
Try using the SetProperty Custom Action in Wise/InstallShield instead of using the Property table.
