Set the permissions in the Registry
Posted 01 December 2001 - 14:46
Thank you for any help
Posted 01 December 2001 - 20:53
Another Admin would be able to read & write HK_LOCAL_MACHINE. A Power User would be able to just read it. A User should able to read it as well, but I haven't had experience with this level of access.
Typically you want to put global information in HK_LOCAL_MACHINE and customized information in HK_CURRENT_USER.
Posted 03 December 2001 - 13:37
Fouad
Posted 03 December 2001 - 15:57
Regini.exe is a versatile tool for making mass changes to the Registry. While not as easy to use as Regedit, it is capable of doing much more than just adding keys and values. You can delete keys and make some minor changes to Registry security. Regini also supports a form of logging that lets you know whether the changes you make actually succeed.
http://www.windowsitlibrary.com/Content/237/2.html
Posted 03 December 2001 - 18:03
However, I don't think that would help him since it wouldn't be accessible from his setup script in order to get this right in the first place.
Posted 03 December 2001 - 18:06
Posted 20 March 2002 - 22:14
I have the same problem. My setup sets the registry entries under HKEY_LOCAL_MACHINE\SOFTWARE. The permissions for the administrators are FULL. Any user who is not an administrator will have only the read permissions.
This is under the machinename\Power Users\.
Is there a way in which we set set the permissions through installshield for all the users?
