Hi All,
I am facing a problem with my installation in Win 95 (4.00.950). I do not face this problem on Win 95 OSR2 or Win98 etc.
I get an error 1603 and the appropriate section of the log file is
MSI © (41:49): Doing action: ISMsiServerStartup
Action start 13:30:49: ISMsiServerStartup.
MSI © (41:49): Creating MSIHANDLE (845) of type 790542 for thread -90039
Action ended 13:30:49: ISMsiServerStartup. Return value 1.
MSI © (41:49): Doing action: ISStartup
Action start 13:30:49: ISStartup.
MSI © (41:49): Creating MSIHANDLE (846) of type 790542 for thread -90039
1: The InstallScript engine version currently installed on this machine is adequate.
1: Event 'E3049590' is created
1: ISMsiServerStartup Failure, Failed to RegisterMsiServer, Error = 0x80020008
1: MsiServerStartup failed. Abort installation.
Action ended 13:30:49: ISMsiServerStartup. Return value 1603.
Action ended 13:30:49: ISStartup. Return value 3.
MSI © (41:49): Doing action: ISCleanUpFatalExit
Action start 13:30:49: ISCleanUpFatalExit.
MSI © (41:49): Creating MSIHANDLE (851) of type 790542 for thread -90039
Action ended 13:30:49: ISCleanUpFatalExit. Return value 1.
MSI © (41:49): Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
Action ended 13:30:49: INSTALL. Return value 3.
MSI © (41:49): Closing MSIHANDLE (845) of type 790542 for thread -90039
MSI © (41:49): Note: 1: 2262 2: Control 3: -2147287038
Can anyone help me and suggest what might be the solution to this problem.
Puneet Pawaia
ISMsiServerStartup error in Win95
pawaia
, Apr 06 2002 09:45
Posted 04 December 2002 - 08:27
Did you get a reply to this posting? I have a similar problem that I am trying to find a solution for.
On a W2K machine with MSI2.0 and ISScript7 installed,
trying to install Symantec Antivirus 8.0. If I log in as an admin user, the install runs successfully, however, if I log in as a gumby user and run the install as the W2K System user, the log file reports a failure by the custom action ISMSIServerStartup - error code 3 is returned. The log file I receive is similar to what you got....
Anyone have an idea?
