I got my installation which is a .exe.
The exe contains the support files the .msi and everything else.
When I launch the exe the first thing display is the window to notify me of require prerequisites. If prerequisites are not required then it move to unpack the .msi and other files and finally unpack the support files.
Well once is done unpacking the .msi the dialog disappears and nothing shows up while the support files are being unpacked.
This gives the impression that the installation has failed. Is there anyway to ensure something is displaying while the support files are being unpacked.
Thx!
Nothing displays...
santlib
, Dec 15 2010 01:36
Posted 15 December 2010 - 12:33
Generate a log to see what's going on. The first dialog in the actual msi file (not InstallShield's initizaition dialog while it extracts the msi file) called SetupInitialization is modeless, so it should stay on the screen until the next dialog shows up.
Posted 15 December 2010 - 17:37
Here is the log up to the point where it fails during the unzip (which is the other issue we are discussing on a different thread) See my comments that start with ***[
=== Logging started: 12/15/2010 8:13:25 ===
Action 8:13:25: INSTALL.
Action start 8:13:25: INSTALL.
Action 8:13:25: ISSetupFilesExtract.
Action start 8:13:25: ISSetupFilesExtract.
1: Starting to extract setup files
1: Getting SUPPORTDIR property :
***[Between this poing....]
1: Extracting SetupFiles to: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\{A884A6C1-FF2D-4C8C-B18D-1F43B8E73DE2}
1: Getting ISSetupFile table view
1: Executing ISSetupFile table view
1: Extracting Setup File:
1: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\{A884A6C1-FF2D-4C8C-B18D-1F43B8E73DE2}\ODAC112012Xcopy.zip
1: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\{A884A6C1-FF2D-4C8C-B18D-1F43B8E73DE2}\7z.exe
1: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\{A884A6C1-FF2D-4C8C-B18D-1F43B8E73DE2}\7z.dll
1: Setting SUPPORTDIR property to: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\{A884A6C1-FF2D-4C8C-B18D-1F43B8E73DE2}
1: Setting ISSETUPFILESCOMPLETED property
Action ended 8:13:49: ISSetupFilesExtract. Return value 1.
***[And this point no dialog or nothing is being display on the screen]
Action 8:13:49: AppSearch. Searching for installed applications
Action start 8:13:49: AppSearch.
AppSearch: Property: DOTNETVERSION20, Signature: DotNet20
AppSearch: Property: DOTNETVERSION20SP1, Signature: DotNet20SP1
AppSearch: Property: DOTNETVERSION30, Signature: DotNet30
AppSearch: Property: DOTNETVERSION30SP1, Signature: DotNet30SP1
AppSearch: Property: DOTNETVERSION35, Signature: DotNet35
AppSearch: Property: DOTNETVERSION35SP1, Signature: DotNet35SP1
Action ended 8:13:49: AppSearch. Return value 1.
Action 8:13:49: LaunchConditions. Evaluating launch conditions
Action start 8:13:49: LaunchConditions.
Action ended 8:13:49: LaunchConditions. Return value 1.
Action 8:13:49: SetupInitialization.
Action start 8:13:49: SetupInitialization.
Info 2898.For Tahoma8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For TahomaBold10 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 8:13:49: SetupInitialization. Dialog created
Action ended 8:13:49: SetupInitialization. Return value 1.
Action 8:13:49: FindRelatedProducts. Searching for related applications
Action start 8:13:49: FindRelatedProducts.
Action ended 8:13:49: FindRelatedProducts. Return value 1.
Action 8:13:49: ValidateProductID.
Action start 8:13:49: ValidateProductID.
Action ended 8:13:49: ValidateProductID. Return value 1.
Action 8:13:49: CostInitialize. Computing space requirements
Action start 8:13:49: CostInitialize.
Action ended 8:13:49: CostInitialize. Return value 1.
Action 8:13:49: FileCost. Computing space requirements
Action start 8:13:49: FileCost.
Action ended 8:13:49: FileCost. Return value 1.
Action 8:13:49: IsolateComponents.
Action start 8:13:49: IsolateComponents.
Action ended 8:13:49: IsolateComponents. Return value 0.
Action 8:13:49: setUserProfileNT.
Action start 8:13:49: setUserProfileNT.
Action ended 8:13:49: setUserProfileNT. Return value 1.
Action 8:13:49: setAllUsersProfile2K.
Action start 8:13:49: setAllUsersProfile2K.
Action ended 8:13:49: setAllUsersProfile2K. Return value 1.
Action 8:13:49: ResolveSource.
Action start 8:13:49: ResolveSource.
Action ended 8:13:49: ResolveSource. Return value 1.
Action 8:13:49: CostFinalize. Computing space requirements
Action start 8:13:49: CostFinalize.
Action ended 8:13:49: CostFinalize. Return value 1.
Action 8:13:49: MigrateFeatureStates. Migrating feature states from related applications
Action start 8:13:49: MigrateFeatureStates.
Action ended 8:13:49: MigrateFeatureStates. Return value 0.
Action 8:13:49: InstallWelcome.
Action start 8:13:49: InstallWelcome.
Action 8:13:49: InstallWelcome. Dialog created
Info 2898.For MSSansBold8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Info 2898.For MSSWhiteSerif8 textstyle, the system created a 'Tahoma' font, in 0 character set.
Action 8:17:24: ReadyToInstall. Dialog created
Action ended 8:17:24: InstallWelcome. Return value 1.
Action 8:17:24: SetupProgress.
Action start 8:17:24: SetupProgress.
Action 8:17:24: SetupProgress. Dialog created
Action ended 8:17:24: SetupProgress. Return value 1.
Action 8:17:24: ExecuteAction.
Action start 8:17:24: ExecuteAction.
Action 8:17:25: INSTALL.
Action start 8:17:25: INSTALL.
Action 8:17:25: ISSetupFilesExtract.
Action start 8:17:25: ISSetupFilesExtract.
Action ended 8:17:25: ISSetupFilesExtract. Return value 0.
Action 8:17:25: AppSearch. Searching for installed applications
Action start 8:17:25: AppSearch.
Action ended 8:17:25: AppSearch. Return value 0.
Action 8:17:25: LaunchConditions. Evaluating launch conditions
Action start 8:17:25: LaunchConditions.
Action ended 8:17:25: LaunchConditions. Return value 1.
Action 8:17:25: FindRelatedProducts. Searching for related applications
Action start 8:17:25: FindRelatedProducts.
Action ended 8:17:25: FindRelatedProducts. Return value 0.
Action 8:17:25: ValidateProductID.
Action start 8:17:25: ValidateProductID.
Action ended 8:17:25: ValidateProductID. Return value 1.
Action 8:17:25: CostInitialize. Computing space requirements
Action start 8:17:25: CostInitialize.
Action ended 8:17:25: CostInitialize. Return value 1.
Action 8:17:25: ResolveSource.
Action start 8:17:25: ResolveSource.
Action ended 8:17:25: ResolveSource. Return value 1.
Action 8:17:25: FileCost. Computing space requirements
Action start 8:17:25: FileCost.
Action ended 8:17:25: FileCost. Return value 1.
Action 8:17:25: IsolateComponents.
Action start 8:17:25: IsolateComponents.
Action ended 8:17:25: IsolateComponents. Return value 0.
Action 8:17:25: setUserProfileNT.
Action start 8:17:25: setUserProfileNT.
Action ended 8:17:25: setUserProfileNT. Return value 1.
Action 8:17:25: setAllUsersProfile2K.
Action start 8:17:25: setAllUsersProfile2K.
Action ended 8:17:25: setAllUsersProfile2K. Return value 1.
Action 8:17:25: CostFinalize. Computing space requirements
Action start 8:17:25: CostFinalize.
Action ended 8:17:25: CostFinalize. Return value 1.
Action 8:17:25: ODACUnzip.
Action start 8:17:25: ODACUnzip.
Posted 16 December 2010 - 16:01
Try moving the SetupInitialization dialog before ISSetupFilesExtract in the Sequences view.
