I modified 4 idt files (component, featurecomponent, file, media). When the msi is run, it says the upgrade ran, but no files are updated.
changes to component.idt:
- Added file with the new ComponentId Guid I created.
changes to featurecomponents.idt
- Added file
changes to file.idt:
- Added file, bumped the sequence count
changes to media.idt
- bumped the last sequence
Changed PackageCode and ProductVersion
What else is left?
Just want to add one file for minor upgrade
alanpi
, Dec 13 2005 02:10
Posted 16 December 2005 - 06:20
What is your REINSTALLMODE set to?
Also, run using a log file, this should help you find the problem.
Posted 19 December 2005 - 19:13
REINSTALLMODE is vamus. I couldn't see the problem in the logs.
Found a fix for my problem. To add a single file to the installation I treated the new file as a subfeature by modifying Feature.idt and FeatureComponents.idt.
I added a new row to Feature.idt to identify the sub feature; i.e. Parent=old feature and attributes = 18.
Here's a reference:
http://msdn.microsof...ature_table.asp
Here's a reference:
