to add a file in "WINSYSDISK" using ISWI edition ??
Posted 30 October 2001 - 11:12
now, i wish i can put some files into the windows boot drive, eg. " C:\ " ??? how i can do it without using install scripts ?
Posted 30 October 2001 - 23:50
Posted 31 October 2001 - 03:18
i've got that !!
mmmmh..... wat 'bout deleting some files when uninstallation....since those files are generated during the run time mode.... some the setup table doesn't recognise 'em and just leave it.....
i heard that RemoveFile table under power editor can perform this but i'd tried.... it seems fails....
any ideas ????
thanx for ur brialliant ideas !! THANX !! :)
Posted 31 October 2001 - 23:30
FileKey: OnAirRequestor
Component: DirOnAir
FileName: WebRequestor.dll
DirProperty: OnAirWeb
InstallMode: 2
The FileKey is just an identifier for the table.
The Component is the name of a component that will gets uninstalled at the same time this file should be removed.
The DirProperty is the name of an entry in the Directory table.
The InstallMode sets the file to be removed when the component gets removed.
