I'm building a differential release from previous full one. I have the "Difference" setting per component as "Include If Appropriate" but I'm still getting lots of files included in the differential build that are the same as the full. Oddly, it's component dependent as I have a few components who's files are being correctly excluded. The files themselves are checked into ClearCase so should be quite traceable as being the same from release to release.
Has anyone else seen this out of differential builds from IS 11.5? Is this a known bug? I'm comparing report files between the release and the files are clearly identical. From the docs, it says it compares file contents (MD5), sizes, timestamps and attributes. Is there something else it's comparing that's non-obvious?
Differential build problem with IS 11.5
fjeske
, Mar 12 2010 00:24
Posted 12 March 2010 - 13:37
Attributes includes the "read only" flag, which I think is changed by some source control systems when you check out a file. Maybe something's going wrong there?
Posted 13 March 2010 - 00:41
The lines in the report files are identical, including the "R" attribute. Quite mysterious.
