There are no references to it anywhere... in IS5/6 you can hide it, but apparently you can't in Windows Installer. Are there ANY workarounds?
cheers and thanks,
Devon
Posted 09 August 2001 - 00:53
cheers and thanks,
Devon
Posted 09 August 2001 - 09:22
Export your project to text file .ISV (see file menu)
Close ISWI
Edit .ISV file in a good text editor
This is a tab delimted file
Search for lines starting with "DlgLine". There are many of these. You can identifiy the target line by checking the nearby string table references.
Note the control number eg. C999
Delete all lines containing C999 or whatever. It should be in a list relating it to the dialog.
Open InstallShield and open the .ISV file. Make a trivial change to your project so that you can save the .ISM file.
You will probably want to do a similar action for Branding1 and Branding2 Text controls.
I reiiterate that making a backup or checking in to source control before you start this could be vital.
Good Luck. I can not help you further on this
Posted 09 August 2001 - 23:49
even InstallShield tech support claimed it couldnt be done... they added sorry, but its a license issue.
No problem, I will include InstallShield text back in the dialogs. I just didnt want THEIR non transparent non movable control. What they fail to realise is that their crappy defaults give you no configurability. Cant make it transparent, cant move it, resizing bugs etc etc. IS need to think about these issues, rather than just brand everything as they see fit. Otherwise if I couldnt do this I would just launch a C++ exe or use a DLL resource for all the Dialog work.
But, again, thanks for your information. You have saved me a lot of time.
Cheers,
Devon
Posted 02 September 2001 - 13:47
Posted 08 October 2001 - 18:15
I can locate the entries you describe but I cannot import the .isv back into ISWI2.03 after I have saved it. I pressume Wordpad is doing something odd to the formatting preventing ISWI2.03 from reading it.
Thanks in advance,
Dave
Posted 09 October 2001 - 16:39
I used Codewright but you do not need such a powerful editor. Most programmer editors will work without a problem. Word processors will not work because they often modify the file beyond your intentions.
Posted 11 October 2001 - 16:57
Posted 18 May 2005 - 23:53
Posted 19 May 2005 - 13:24
