Hi all ,
Please help me out ,I m using installshield developer 7 with a update of 7.01. I m stuck with a problem that if i try to uninstall or modify my installer by clicking Change/Remove button from Add Remove panel, the text of first dialog which is default dialog by installshield which says "Set up is preparing the installshield wizard which will guide through............................" appears in bold text each time ,which is creating problem as client is not happy.
If any one knows how to get it back to normal text ,pls pls..... help me out ..
Gaurav
Text Bold problem
Gaurav Gupta
, Nov 21 2005 08:15
Posted 22 November 2005 - 20:33
Does the same happen is you create a fresh test project?
