During File Transfer of an IS 6.30 setup I get the following error message:
Component Transfer Error
Component: XYZ
File Group:
File:
Error: The filename, directory name or volume label syntax is incorrect.
My test constellation:
One setup contains three components, each of which contains one Installshield-object.
Each object contains one component with one file group, whose 'Target'-property is set via a variable, e.g <Basis1>. The value of this variable is set in the ..._Installing event of the component, like this: ComponentSetTarget(MEDIA, "<Basis1>", sPath).
Interestingly the error doesn't occur when I set the 'Target'-property to <TARGETDIR> in objects 2 and 3. In that case the method I described works.
Thanks a lot for your suggestions!
