During installation, I moved over .jar file, then unzip the jar file. The problem is, during uninstall, I want to remove those unzipped files. But I couldn't do it because it is not moved over directly. Is there any way to remove those files
Uninstall
mindylchen
, Feb 25 2002 18:04
Posted 25 February 2002 - 23:18
Since you're probably using the event-based model, simply add the necessary delete file commands to the OnMaintUIBefore( ) function just after the following commands:
switch(nType)
case REMOVEALL: ComponentRemoveAll();
If this function doesn't exist, you can add it via the drop down function lists of "Before Move Data" and "Maintenance UI Before".
Hope it helps.
