I have custom actions that runs some exes where I check the exit code.
If the exit code is wrong (1 I think) the installer displays a message box informing the user that the current action finished with exit code 1.
How can I change the text displayed in the message box?
I'm using InstallShield
Custom action exitcode
cornel_gav
, Mar 13 2008 09:48
Posted 13 March 2008 - 10:04
Ah, the joys of return values...One day, MS will standardise on return values. Quite why it decided that most functions should return 0 as success but others a non-zero value has always alluded me. Then to compound the confusion by using '1' as the success value for CAs in Windows Installer....it defies belief, it really does. Anyway....
| How can I change the text displayed in the message box? |
You can't, it's built in to the Windows Installer engine. Better to handle the error 'internally' to your CA and present your own dialog/MsgBox there (you can use the IE object to present dialogs as an alternative to MsgBox). If the return value of the CA determines some future action/inaction, set a Windows Installer property (or registry entry) accordingly.
Edited by VBScab, 13 March 2008 - 10:04.
Posted 13 March 2008 - 10:39
Most, if not all, messages generated by the Windows Installer are listed in the Error table and UIText table.
Posted 13 March 2008 - 12:38
| Most, if not all, messages generated by the Windows Installer are listed in the Error table and UIText table. |
Really? Create a guaranteed-to-fail CA (e.g. run a non-existent EXE or an EXE with an invalid argument) and see if a single sentence from either of those tables appears in the resulting dialog. Certainly some of the *common* errors appear in the Errors table (1603 and so on) and one can add the missing ones if desired.
@cornel_gav, What I think you're saying is that the *EXE* returns a non-zero value. As I mentioned, a return value of 1 from a *CA* indicates success, not failure. MS guidelines state that EXEs return zero as a success failure and anything else indicates a failure. Did you author the CA? I suspect this is a vendor MSI calling perhaps a DLL function, in which case, you're stumped and you'd be better off trying to determine why the call is failing.
