Habe InstallScript Project (ohne MSI)
Möchte von meinen *.msi Files die GUID nur auslesen und ...
Beim Auslesen von zweitem msi-File bekomme Error 1631: -> ERROR_CREATE_FAILED The database could not be created.
// The Windows Installer service failed to start. Contact your support personnel.
Habe gesucht. Fand ich:
http://us.generation-nt.com/answer/vb-open-two-databases-second-fails-1631-help-52140942.html
October 03rd, 2004 Dennis Bareis
VB to open two databases, second fails with 1631
Wie soll ich meine Scripte ändern?
Brauche Eure Hilfe dringen.
Dazu mein Script:
-- setup.rul --
#include "IsMsiQuery.h"
#include "MsiFuncsConv.h"
// meine function
prototype BOOL dltMsiNew_GUID(STRING, STRING, STRING, BYREF STRING);
prototype number MSI.MsiViewClose(HWND);
if dltMsiNew_GUID(WINSYSDIR, "msi.dll", "xx.msi", svProductGuid) then
endif;
function BOOL dltMsiNew_GUID(szMsi_Directory,szWindMsiDll,szdltProduct_Msi,szOld_MsiProduct)
// return - szOld_MsiProduct = ProductCode
HWND hdltProd_MSI, hdltProd_Record;
string sz_MsiFile_Control, svProductGuid[128];
number nvOpenMsiDll, nvCount, nvCount_Record;
BOOL bv_Product_Msi;
begin
bv_Product_Msi = TRUE;
sz_MsiFile_Control = szMsi_Directory ^ szWindMsiDll;
nvOpenMsiDll = UseDLL(sz_MsiFile_Control);
nvOpenMsiDll = MsiOpenDatabaseA(szdltProduct_Msi, MSIDBOPEN_READONLY, hdltProd_MSI);
// probiert habe mit: nvOpenMsiDll = MsiOpenDatabase(szdltProduct_Msi, "0", hdltProd_MSI);
switch (nvOpenMsiDll)
case ERROR_CREATE_FAILED:
// MessageBox(" MsiOpenDatabaseA -> ERROR_CREATE_FAILED The database could not be created.",INFORMATION);
bv_Product_Msi = FALSE;
case ERROR_INVALID_PARAMETER:
// MessageBox(" MsiOpenDatabaseA: One of the parameters was invalid.",INFORMATION);
case ERROR_OPEN_FAILED:
// MessageBox(" MsiOpenDatabaseA: The database could not be opened as requested.",INFORMATION);
case ERROR_SUCCESS:
// MessageBox(" MsiOpenDatabaseA: The function succeeded.",INFORMATION);
endswitch;
nvCount = 127;
nvOpenMsiDll = MsiDatabaseOpenViewA(hdltProd_MSI, "Select `Value` From Property WHERE `Property` ='ProductCode'", nvCount);
nvOpenMsiDll = MsiViewExecute(nvCount,0);
nvOpenMsiDll = MsiViewFetch(nvCount, hdltProd_Record);
nvCount_Record = 127;
nvOpenMsiDll = MsiRecordGetStringA(hdltProd_Record, 1, svProductGuid, nvCount_Record);
szOld_MsiProduct = svProductGuid;
nvOpenMsiDll = MsiViewClose(nvCount);
nvOpenMsiDll = MsiDatabaseCommit(hdltProd_MSI);
nvOpenMsiDll = MsiCloseHandle(hdltProd_MSI);
if ( UnUseDLL(szWindMsiDll) < 0 ) then
// MessageBox("UnUseDLL: Indicates that the function was unable to unlock or unload the .dll file.\n" + szWindMsiDll,INFORMATION);
endif;
return bv_Product_Msi;
end; // function dltMsiNew_GUID()
Danke im Voraus
second MsiOpenDatabaseA()
bernard
, Apr 26 2011 14:55
Posted 28 April 2011 - 06:19
Es wurde ein File mit Namen "0" im SRCDIR immer erstellt.
Die Lösung:
Statt
habe so eingetragen:
GetEnvVar("TEMP", szTempDirectory);
ParsePath(sv_Temp_Product_Msi, szdltProduct_Msi, FILENAME_ONLY);
sv_Temp_Product_Msi = sv_Temp_Product_Msi + ".xxxx";
sv_Temp_Msi = szTempDirectory ^ sv_Temp_Product_Msi;
nvOpenMsiDll = MsiOpenDatabaseA(szdltProduct_Msi, sv_Temp_Msi, hdltProd_MSI);
Es wird ein neues File pro msi-File im %TEMP%-Verzeichnis erstellt.
Problem
Kann es später nach MsiCloseHandle() und UnUseDLL() nicht löschen.
Habt ihr eine Idee?
Danke im Voraus
Die Lösung:
Statt
Problem
Habt ihr eine Idee?
Danke im Voraus
Edited by bernard, 28 April 2011 - 06:21.
Posted 28 April 2011 - 06:28
| Kann es später nach MsiCloseHandle() und UnUseDLL() nicht löschen. |
if (DeleteFile(sv_Temp_Msi) = 0) then
MessageBox(" DeleteFile-" + sv_Temp_Msi,INFORMATION);
else
MessageBox(FormatMessage(LAST_RESULT),SEVERE);
endif;
Kommt: Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird.
Posted 18 July 2011 - 11:35
| Der Prozess kann nicht auf die Datei zugreifen, da sie von einem anderen Prozess verwendet wird. |
Die Lösung:
Es fehlt eine MsiCloseHandle() noch.
Jetzt ist im Script so:
nvOpenMsiDll = MsiDatabaseOpenViewA(hdltProd_MSI, sz_Select_Property, nvCountOpenView);
nvOpenMsiDll = MsiViewExecute(nvCountOpenView,0);
nvOpenMsiDll = MsiViewFetch(nvCountOpenView, hdltProd_Record);
nvOpenMsiDll = MsiViewClose(nvCountOpenView);
nvOpenMsiDll = MsiCloseHandle(nvCountOpenView);
Werden die temporary Files im %TEMP%-Verzeichnis gelöscht.
