Hi
I have IS2008 and a Basic MSI Project.
I need to merge some modules (.MSM files) during build time.
I was using version IS12 earlier and there was an option (-o ) to the command line build utility IsSaBld.exe that lets you modify the search path for Merge modules. I do not see this option available in this version with its command line build utilities IsCmdBld.exe or IsBuild.exe.
What is the equivalent method in this version for the above?
Thanks!
IsCmdBld/IsBuild Utility to Merge Module
felixmat
, Mar 07 2008 23:12
Posted 10 March 2008 - 15:12
I'm not sure but I guess it uses the same search path as the InstallShield IDE. But why don't you continue to use the stand alone bild tool (IsSaBuild)?
