I'm using DevStudio 9 and was wondering if anyone knows if it is possible to get the maintenance UI if a user selects the Remove button from the Add/Remove programs in the control panel? I understand that by default that it follows the execute sequence, but is there a way to bring up the maintenance UI instead?
D
Maintenance UI from Add/Remove
dtbaker
, Nov 11 2003 00:32
Posted 11 November 2003 - 09:41
Control panel launches the install in basic UI mode and I don't think you can change this once your setup is running. The workaround would be to disable the Remove button.
