I would appreciate your responses. thanks!!
Posted 08 February 2015 - 21:34
Posted 12 February 2015 - 11:04
You can control services in the Service view (Installation Designer: System Configuration > Services).
Right click to add a service entry.
If you want to control an existing service, set "Enable Service Install" to No.
Under Control Settings click the green + sign to add an event
Expand the Operation Time node and set InstallStart to No and Install Stop to yes.
That should stop the service during install.
Add another event to start the serice during uninstall.
To kill a process go to Behaviour and Logic > Custom Actions and Sequences. Right click the Custom Actions root node and select New Kill Process. Then you need to add a property in Property Manager that specifies the process that should be killed. For details please see the help topic about the kill process custom action.
Posted 12 February 2015 - 22:08
Posted 13 February 2015 - 17:53
Funlctionality to create, remove, start and stop services is also available in Component view under the advanced settings of the component.
