I'd like to combine CheckBox and GroupBox , somethink like MFC dialog stile , when I select check box all control into groupbox are enabled and contrariwise.
Everythink works fine I have only visual probrem with checkbox. The groupbox appears above checkbox, until I move mouse to the checkbox , it seems that checkbox needs same refresh or redraw. I tried to fix it by changing tab order , but nothing helps, Groupbox always appears above of checkbox when dialog appears.
Any ideas?
CheckBox with GroupBox
Kiril
, Sep 10 2004 20:26
Posted 11 September 2004 - 10:46
Make that both controls have the tab stop bit set, and the group box comes before the check box in tab order.
