Dear All,
Iam using two ways to install Msi package
1)First way Through Custom Action(nested Msi) in devstudio 9.0 version.
2) Second way iam trying to Convert Msi to EXE after Converting To exe i will start to install.
Which is Correct Method to Install .Msi file along with my Software, guide me.
regards
Narayana Moorthy.V
RE:MSI Installation
devstudio.2007
, May 09 2008 06:46
Posted 09 May 2008 - 08:15
If you package your msi in a exe it is still an msi, so that won't work.
Nested install custom actions are deprecated.
The recommended way is to have a chainer exe that will run the two MSIs in a row.
Posted 09 May 2008 - 08:34
How to to that????? i want to install .msi in silent way guide me..
regards
Narain
regards
Narain
Posted 11 May 2008 - 17:42
Depending on the InstallShield version you have, you could use the Prerequiste functionality, or create your own setup.exe for the purpose. There are samples on the web.
To run a "InstallScrtipt MSI" (not a "Basic MSI") setup silently you need to create a .iss resonse file.
