Hey guys,
I've created a BASIC MSI project, which works without any problems under windows xp and 7 (32 and 64 bit). But I got several problems running it on a windows 8 machine.
FYI: The setup needs to be run with administrative rights. I've tested it on a windows 8 virtual machine (64 bit) with UAC (level: standard).
At the end of the setup a script is called to create a desktop shortcut of my application. This should also happen on windows 8 machines (although the desktop has a different meaning there). The script works perfectly under earlier winodws versions. Below u can see the code to create that shortcut:
Windows 8 Errors
Sandor1990
, Feb 20 2013 15:56
Posted 20 February 2013 - 15:56
function CreateShortcut_Desktop(hMSI) STRING szProgramFolder, szItemName, szCommandLine, szWorkingDir, szIconPath; STRING szProgramDir, szPathToExe; NUMBER nIcon, nBufferSize; begin nBufferSize = MAX_PATH; MsiGetProperty(ISMSI_HANDLE,"SETUPEXEDIR",szPathToExe,nBufferSize); if(FoundExe(hMSI)) then szProgramDir = FOLDER_DESKTOP; szItemName = "My Shortcut"; nIcon = 0; szCommandLine = "\"" + szPathToExe + "\\..\\MyApplication.exe\""; szWorkingDir = szPathToExe + "\\..\\"; szIconPath = szPathToExe + "\\..\\MyApplication.exe"; AddFolderIcon(szProgramDir, szItemName, szCommandLine, szWorkingDir, szIconPath,0,"",REPLACE); else MessageBox(@IDS_ERROR_COULDNT_FIND_MYAPPLICATION, INFORMATION); endif; end; |
When running the stup with the first user created on the windows 8 machine (this user is the admin and is in group administrators), I get the following effects:
- a working shortcut is created on the desktop
- a second shortcut is created as tile on the windows 8 start screen in metro style. But this shortcut doesn't work. It points to C:\MyApplication.exe (where my application isn't installed to). Does anybody know how to avoid this shortcut on the windows 8 start screen? Or how to make it run (so it actually points to the location where my application is stored)?
Next issue when running the setup with a second user (which is also in the adminitrator's group, but is not the user 'administrator'):
- no shortcut is created. Does windows 8 prohibit (due to UAC) to run scripts?
I'm looking forward to any answers of you!
Cheers,
Sand0r
Posted 20 February 2013 - 16:43
