Component deleted during major update
Posted 07 March 2005 - 15:56
I got the following problem:
I have an MSI based install created with Installshield using (1.1 schema) so it does not need msi 2 installed. Now I have create a major update changing the productcode, packagecode and version number.
The major upgrade works as normal. I see found application and removing older versions, etc. But at the end I am missing a few components. When I do a repair it works fine, but without repair the components are missing.
For the missing components the following line is in the log file for the installing part (s).
Installed: Absent; Request: Local; Action: Null
And it does what is says not installing my component. My removeexisting product action is between installvalidate and installinitialize so I am really confused now.
Anybody with an answer to this?
Thanks, Raoul
Posted 09 March 2005 - 14:47
Posted 10 March 2005 - 17:24
So I had expected any serious issues during a major update.
Raoul
Posted 11 March 2005 - 10:25
Posted 14 March 2005 - 15:29
the verbose log told me the following:
What else do I need to look for?
Thanks, Raoul
Posted 14 March 2005 - 18:25
Any SELMGR messages?
Posted 16 March 2005 - 11:33
I have created a different major update and now a different component is removed. It seems consistent per major update, but If I author a new major upate it affects other components.
I have attached the verbose logging (deleted a few bits to drop below 100k, but I think these are not the bits it is about).
The component that is deleted and not installed again is called EVTime.exe. You will see request local action null for that item, but that's all I can find.
Any ideas?
Thanks, Raoul
Posted 18 March 2005 - 11:49
Posted 18 March 2005 - 14:30
Where / How is the best way to contact Microsoft with this problem?
Raoul
Posted 21 March 2005 - 09:11
Posted 21 March 2005 - 12:31
Raoul
