Help with Smart CD Autorun Launcher
Posted 23 June 2004 - 17:25
I found the readme for Smart CD Autorun Launcher which should help me get around this but it's very confusing and I was looking for more thorough instructions to clarify. The readme file is this;
; Smart CD Autorun Launcher
; by Dipl.-Ing. Stefan Krueger
; <skrueger@installsite.org>
[Application]
; Enter the registry location of for your application's App Path entry under
; HKEY_LOCAL_MACHINE. InstallShield creates this entry with the call
; RegDBSetItem( REGDB_APPPATH_DEFAULT, szAppPath ^ @PRODUCT_KEY );
; RegKey=""
; Should application be started automatically if it is already installed?
; (Boolean: 0 or 1)
Start=0
[Setup]
; Specify absolute path to your main setup program. The drive letter (with
; colon) will be prepended automatically
; You can also add command line parameters. Example:
; Run=\setup\setup.exe /SMS
; Do not use long file names!
Run=\Detect.exe
; Specify your game's window class. Required to prevent launching of multiple
; instances of setup if CD is removed and re-inserted during installation.
WindowClass=Jedi Knight 2
; Additionally specify your setup's window title (optional)
; WindowTitle=
I can't find a registry in HKEY_LOCAL_MACHINE nor can I find a registry file to import into HKEY_LOCAL_MACHINE. I'm also unsure what to put in the RegKey="" once I've done the first part.
I'm probably doing something entirely wrong and I was wondering if you'd be able to clarify the first part of that Readme file for as it appears thats the only one which I need to do manually.
bonfire
Posted 24 June 2004 - 06:46
Posted 24 June 2004 - 21:03
bonfire
Posted 25 June 2004 - 14:26
Posted 27 June 2004 - 10:52
Posted 20 December 2013 - 02:24
I know this is old, but I found this info in a game file for Vampires Masquerade Redemption. The game will not run on Win 7 64 bits but I have been seeing posts all over that it can work..... any thoughts. The game is the original disks not a download.
; Smart CD Autorun Launcher; by Dipl.-Ing. Stefan Krueger; <skrueger@installsite.org>[Application]; Enter the registry location of for your application's App Path entry under; HKEY_LOCAL_MACHINE. InstallShield creates this entry with the call; RegDBSetItem( REGDB_APPPATH_DEFAULT, szAppPath ^ @PRODUCT_KEY );RegKey="Software\Activision\Vampire The Masquerade - Redemption\INSTALLDIREXE\Vampire.exe"; Should application be started automatically if it is already installed?; (Boolean: 0 or 1)Start=0[Setup]; Specify absolute path to your main setup program. The drive letter (with; colon) will be prepended automatically; You can also add command line parameters. Example:; Run=\setup.exe; Do not use long file names!Run=\setup\setup.exe; Specify your setup's window class. Required to prevent launching of multiple; instances of setup if CD is removed and re-inserted during installation.WindowClass=InstallShield_Win; Additionally specify your setup's window title (optional);WindowTitle=Vampire The Masquerade - Redemption
Edited by nikademis, 20 December 2013 - 02:24.
Posted 20 December 2013 - 17:35
You could try running D:\setup\setup.exe (replace D with the drive letter of your CD-ROM drive). If that doesn't work, please contact the game manufacturer.
