InstallScript Problem
Posted 30 July 2001 - 18:13
Posted 31 July 2001 - 16:00
Posted 01 August 2001 - 01:35
Posted 01 August 2001 - 11:36
Basically the script engine crashes, your installscript will still compile in the IDE but as soon as it comes across a CA written with installscript in will just quit the install with "Setup interupted."
The problem is specific to InstallScript CA's so if its a small project you could use a dll or C to write your CA, but I know myself this is not always practical.
Search "Script Engine" in the Newsgroup Archive: http://isnews.nextpa...news....n-j.htm for more info.
The solution seems to be deleting the Program Files\Common\InstallShield folder and then running Repair from Add/Remove Programs to re-register the engine.
While getting it working your probably better creating a blank setup with an InstallScript CA prompting MessageBox and then step-through see if that helps.
Dave.
Posted 01 August 2001 - 17:37
