Hi all
I am doing a system search via the wizard to find the MSSQL folder on a server. In the system search wizard I have set the following : -
* folder name to search for is MSSQL
* look in all drives
* number of sub folders to search = 0
I am having bother with the sub folders parameter. Surely 0 means that no subfolders will be searched? The normal location for our customers mssql folder is on the root of a drive (e.g. c:\mssql) and this is the path I am looking for.
Recently, it is returning c:\program files\microsoft sql server\mssql$bkupexec but that is within a subfolder structure, so why is this path being found?
can anyone advise please, thanks
Donna
system search
Donzer
, Jun 06 2006 11:19
Posted 07 June 2006 - 08:40
Double check the actual data in the built .msi file using direct edit mode or Orca, table DrLocator.
