I am trying to update a shared COM interop assembly. Windows Installer does not uninstall the assembly before updating it, so obsolete entries may be left in the registry. I have tried adding entries to the RemoveRegistry table, but it appears the entries are removed without regard to ref counts. So, if I have another application that still refers to the old version, my RemoveRegistry entries will break it.
Any suggestions on how to properly get rid of the obsolete registry entries? I only want to remove them when there are no more references to them.
My component is shared, so I supply a merge module. Therefore, I do not have control over what kind of update (major, minor, small) is performed, or how it is deployed (patch or update).
Thanks in advance,
Karen
Update of shared COM interop assembly
kfraserwork
, Feb 02 2006 00:20
Posted 02 February 2006 - 10:27
If you take a look at what Stefan says in http://forum.install...showtopic=10286 he indicates that the shared COM Interpop registry entries should be in the Registry table and not in the Class, ProgID etc tables.
How are your COM Interops registered?
I am having trouble just getting my Interop DLLs registered so I guess your problem is one I am about to come to. I too have the DLLs in a merge module.
Posted 02 February 2006 - 19:31
I am using InstallShield which inserts the appropriate entries into the Registry table. There are no entries in the Class or ProgID tables.
Does anyone know of any problems I might run into if I leave the obsolete entries in the registry? I hate the idea of leaving garbage in the registry, but I see no alternative.
