I know that if I have features
a, b, c, d, & e
if a alone is min
a, b, c is normal
and
a,b,c,d,e is full i can set the install level like this (mult. of 10 for adding in future things)
a = 10
b = 20
c = 30
d = 40
e = 50
min install level = 10
normal install level = 30
full install level = 50
BUT what if I have multiple install combinations that have mutually exclusive features, can I accomplish something similar through install level or otherwise?
I.E.
Features a, b, c, d, e, f
a is normal
a, b, c is config A
a, d, e is config B
a, f is conifg C
a, b, c, d, e, f is full
Multiple Feature Levles
_nick_
, May 12 2005 14:24
Posted 13 May 2005 - 08:14
You can't do that with install levels. But you can use AddLocal and Remove control events on the Next button of the setup type dialog to select the desired features. Use conditions on those events that depend on the selected setup type.
Posted 13 May 2005 - 13:13
What I figured, but I was hoping that someone would know a trick I didn't
