Hy
I need to copy several files and folders in IS6.3 Pro by script. So, I use XCopy... If there exists already some files or folders, the script must not overwrite these existing files or folders. The matter is, that XCopy doesn't support the "property" - do not overwrite (at all)... Has anybody an idea, how to solve this?
Thanks in advance
smilie
Switzerland
XCopy - do not overwrite Files!?!
smilie
, Mar 24 2003 17:35
Posted 24 March 2003 - 23:43
1.Add the names of the files you are going to Xcopy() to a list.
2.Then, scroll through the list and use the FindFile() function.
a.If the file exists, then do nothing. FindFile() returns 0 (zero)
b.If the file does not exist, then Xcopy(). FindFile() returns <0 (negative)
Repeat as necessary for each folder.
