Hi all,
Does anyone have any experience with modification of MSI database files using queries from VB6?
Specifically, I am using the Automation interface to open a .msi file in edit mode.
( no problems there).
Then I am trying to add the text of a license agreement rtf file into the LicenseAgreementDlg textbox control. I attempt to execute an update query, but I get an error when I try to open the view.
Any suggestions?
My code looks something like this:
'Read agreement text from specified file, open Control table and add
'the text to the AgreementText control of LicenseAgreementDlg
Sub AddLicenseAgreement(ByRef strLicenseFile As String)
Dim objView As View
Dim strLicenseText As String
Dim strSQL As String
'Get the license text from the rtf file
strLicenseText = ReadRTFFile(strLicenseFile)
'Assemble the update query string, enclosing text in single quotes
strSQL = "UPDATE Control SET Control.Text=" _
& "'" & strLicenseText & "'" _
& " WHERE Control.Dialog='LicenseAgreementDlg'" _
& " AND Control.Control='AgreementText'"
With g_MSIDatabase
'Execute the update query
Set objView = .OpenView(strSQL)
'Close the view
objView.Close
'Commit the msi database changes
.Commit
End With
End Sub
TIA,
R
Modification of MSI database from VB6
rgraham
, Nov 06 2003 22:59
Posted 07 November 2003 - 02:49
Hmm, sorry I have never done anything like this. Here is some sample code that I use to update the "Upgrade" table in my database during build automation. It is very different, but maybe it gives you an idea:
| Set oneWindowsInstaller = CreateObject("WindowsInstaller.Installer") Set oneInstallerDatabase = oneWindowsInstaller.OpenDatabase("C:\BasicMSI.ism", 1) ' Set up SQL query for the upgrade table - DETECT NEWER VERSION INSTALLED Set oneView = oneInstallerDatabase.OpenView _ ("SELECT * FROM Upgrade WHERE ActionProperty = 'CHECKCURRENTINSTALL'") ' Execute the view, so its methods can be used. oneView.Execute 'Fetch records Set oneRecordObject = oneView.Fetch ' Assign new values to recordset oneRecordObject.StringData (2) = V_MAJOR & "." & V_MINOR & "." & V_BUILD oneView.Modify 4, oneRecordObject oneView.Close Set oneRecordObject = Nothing |
Posted 07 November 2003 - 19:56
Thanks, that was very helpful. My final code is shown below.
Public Const CONTROL_TEXT_FIELD = 10 'Const for Text field index in Control Table 'Read agreement text from specified file, open Control table and add 'the text to the AgreementText control of LicenseAgreementDlg Sub AddLicenseAgreement(ByRef strLicenseFile As String) Dim objView As View Dim objRecord As Record Dim strLicenseText As String Dim strSQL As String 'Get the license text from the rtf file strLicenseText = ReadRTFFile(strLicenseFile) 'Assemble the query string to retrieve the record for the AgreementText control strSQL = "SELECT * FROM Control WHERE Control = 'AgreementText'" 'Open the view Set objView = g_MSIDatabase.OpenView(strSQL) With objView .Execute 'Fetch the record Set objRecord = .Fetch 'Replace the string with license agreement objRecord.StringData(CONTROL_TEXT_FIELD) = strLicenseText 'Call the modify method to update the field .Modify msiViewModifyUpdate, objRecord 'Close the view .Close End With 'Commit the msi database changes g_MSIDatabase.Commit End Sub |
Posted 07 November 2003 - 19:59
Glad to be of help, and thanks for posting your completed code! I will add it to my script repository.
