Hi all,
I have developed Setup.exe ( pure msi) for our product. For upgrades we will be providing minor upgrades with REINSTALLMODE = vemus REINSTALL=ALL command in commandline.
Now say i have version 1.0.5 on target machine and if i try to install 1.0.6 the upgrades installs perfectly without showing maitenance dialog.
Now when i try to run 1.0.4 or lesser version nothing really happens. The setup.exe just dies down. I know it is not good to downgrade a product, but if the user might just un-knowingly double click the setup.exe and start wondering whats wrong. What one would expect is some dialog telling the user that you can't downgrade the product.
Now i digged deeper with regmon and setup.exe queries the regkey. There i found access to following key...
HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\925BD622B62E52040A406C5E1FA7D22C\InstallProperties\DisplayVersio
and its value is 1.0.5 and i guess setup.exe wont run if the current version is lesser than this value. Now i manually changed this value for the testing purpose to 1.0.2 and tried to run 1.0.4. The setup.exe did run perfectly. ( at least the initialization dialogs did appear).
Now i really dont know who is checking for the version ( as i guess msiexec process is really not invoked up to this point).
Can some body tell me is there a way to tell the user that he can't downgrade the product.
Thanks and regards
Sarfu
Setup.exe not launching
sarfu
, Sep 27 2007 13:16
Posted 28 September 2007 - 16:35
I believe it's your setup.exe, not msiexec, checking that entry. Contact the author of the setup.exe as he would need to modify it. s this a standard setup.exe from some msi authoring tool?
Posted 04 October 2007 - 09:31
Thanks Stefan,
I found it was my problem.
I had disabled the "prompt for upgrade options in upgrade section" and that was terminating setup.exe, when i try to install with lower version.
Sarfu
Sarfu
