I am a newbie to InstallShield. I am using Installshield 2010 Professional edition to create a Basic MSI setup project for my application.
In this project I want to include a redistributable msi, and I want to run this based on some custom condition.
ie, I want to check is there is any registry key exists with a specified registry value under a particular registry key. So I have to check each child nodes of that registry key.
Using InstallShield Prerequisite editor I can check a particular registry value, but there is no way to search all child nodes.
Is there is any way to implement this ?
Is it possible to execute custom action in prerequisite window?
Thanking you in advance
Jaz
Adding custom condition to a prerequisty
jazeelkm
, Nov 17 2009 07:44
Posted 17 November 2009 - 08:04
No, you can't use custom action in the prerequisite editor.
Maybe you could make it a feature dependent prerequisite, and select or un-select the (hidden) feature based on your search results.
