I really appreciate any help you could provide as i am very new to msi.
In my destination folder dialog box ( after clicking on next) , i am calling DoAction event with an argument to installscript function. This function sets a MSi property called "USERID" to value either MIKE or JOSEPH or MARK or GLEN
I have four different features called " MIKE , JOSEPH , MARK , GLEN. Depending upon the value of USERID i want to display one feature and hide other features.
For example : If USERID is set to "MIKE" , in custom setup dialog box, only feature "MIKE" should get displayed and other features should be invisible.
After reading earlier posts ,i found that :
I can't use feature condition builder as it evaluates the condition before costinitialize.
I tried using AddLocal & Remove events and it disable the other features in custom setup dialog box but installer can still enable as they are still visible.
Please let me know what should i do make it work as i really want other features to be invisible or disabled.
Making features Invisible- please help
tuteja
, Apr 07 2008 15:15
Posted 08 April 2008 - 08:03
This can't be done exactly like you wish. Here are your options:
- Call your custom action before CostInitialize (i.e. insert a dialog before CostInitialize)
- Don't use the FeatureTree dialog. Instead create a dialog with check boxes per feature, which can esily be made invisible.
- Remove CostFinalize from the sequence and call it from your dialog (this can be tricky)
- Don't use MSIs built in user interface but create an external UI on your own (lots of work)
Posted 08 April 2008 - 22:17
Thanks Stefan for your help and sorry for my direct email.
what i did is :
1. I set all the 4 features MIKE , JOSEPH , MARK , GLEN as invisible ,disallow advertise and required set be "no" in setup design.
2. I used AddLocal & Remove events in Destination folder box depending upon MSIpropery [USERID] set in installscript
3. In custom setup dialog box, i am just displaying a text line saying "
Features for [USERID] will get installed.
Please let me know if you see any issue here.
what i did is :
