Hello,
I’m using Install Shield 11. I have a problem which I want to describe to you below.
I have a *.msm which contains some *.dll files. I just want to call in the main MSI package a function from one *.dll file which is part of the msm. That function returns a value. Depending of the value that is returned, I have to condition some other action in the main MSI package.
I observed that in the msm, can be called only the function from a msi.dll – this is not a option for me. I wanted to create a CA in the msm but I wasn’t allowed to do that (available are only: *.exe, msi.dll, VBScript, VJScript, SetProperty, SetDirectory).
So, to insert in the main msi package a CA, that CA must be created in the msm file.
My question is, can it be possible to call a function which returns a value from the static *.dll file in the msm that includes that dll?
Thanks in advance,
Sebastian
calling a function
sebica79
, Jan 26 2006 11:53
Posted 27 January 2006 - 18:30
Basically you need a wrapper "msi dll" that will call you standard DLL and will also handle the return value. InstallShield's Standard DLL custom action type is such a wrapper. Have you tried using that and specified the DLL fromm the custom action as DLL being called? Remember that you cannot do this before InstallFiles action (with a deferred custom action) resp. not before InstallFinalize (for immediate custom action)
