I don't want my program to be displayed in the Uninstall list. Is there any way to do that? I tried to set ARPSYSTEMCOMPONENT property to 1 or set the Display to empty in registry. But neither of them worked for ISD 7.0. does anyone know how to do it?
HJ
How to prevent the application from being displaye
hjia
, Jul 01 2002 15:25
Posted 12 July 2002 - 23:27
add this line under the [startup] section of the setup.ini
NoAddRemove=y
you need to compile the install so you have a setup.exe and setup.ini.
NoAddRemove=y
Posted 12 July 2002 - 23:28
also, each time you compile you will have to add it back either manually or with a small exe or batchfile.
