HI,
Please somebody explain me how I can Install admin image on network and then as a regular network user How I can install application on my local machine from that remote network image with some transforms?
Thanks in advance..
-vPuL
Administrative Install
vnadoda
, Sep 26 2002 18:53
Posted 08 October 2002 - 17:53
prior to installation we make sure the System and User policies are set to AllwaysInstallElevated. at the time of install we use a ALLUSERS=1 property on the command line.
Admin Installs:
typically the .EXE used to launch the application ( ie. Setup.EXE ) is called with a "/a" switch to tell it to perform an admin. install.
NOTE: if you plan to copy this uncompressed set of files to cd and install from there you will most likely have to set the "DISABLEMEDIA" property to "" ( i believe that this can also be set using the DisableMedia local user policy but i haven't personaly done this...)
good luck...
Admin Installs:
good luck...
