I am building a project using ISWI Ver. 1.52. In this project I am trying to run a separate install exe to install third party drivers. I have created a custom action called MyFunction, which is called after InstallFinalize. The script compiles as Setup.rul with 0 Errors and 0 Warnings.
Here is the script;
#include "isrt.h"
#include "iswi.h"
export prototype MyFunction(HWND);
function MyFunction(hMSI)
STRING szProgram, szCmdline;
begin
szProgram = "WINDIR^cmd.exe";
szCmdline = "C:\\Dongle\\install.exe /b";
LaunchAppAndWait (szProgram, szCmdline, WAIT);
end;
When I run the build in “Debug My Release” the script is called and displayed in InstallShield Script Debugger Ver. 6. The rest of the installation waits just as expected.
As I step into the script the variable szProgram gets set as “C:\WINNT\cmd.exe”
The variable szCmdline gets set as “C:Dongleinstall.exe /b” Of course the syntax is not correct for a command line argument so the install.exe doesn’t run. After completing the script ISWI continues with the rest of the install without error.
What is the correct syntax in the Installscript to display this command line properly?
Thanks for your help.
Passing Command line Arguments with CA
MikeG
, Sep 22 2004 19:00
Posted 23 September 2004 - 07:24
The following should work.
szProgram = WINDIR ^ "cmd.exe C:\\Dongle\\install.exe ";
szCmdline = "/b";
szCmdline = "/b";
Posted 23 September 2004 - 17:05
Thank you for the reply AshinSmart. I tried as suggested and the 2 strings, szProgram and szCmdline are still displaying the same in the debugger.
szCmdline “C:Dongleinstall.exe /b”
szProgram “C:\WINNT\cmd.exe”
Is there a legacy file that needs to be removed to get the script to recognize the new syntax?
Thank you for sharing your brain.[br]Mike G.
Posted 01 October 2004 - 05:58
Very Sorry Mike,
Here comes the actual solution.
I am presenting a sample code, which actually works for me.
| function RegisterMyRegSettings(hMSI) STRING RegPath; begin RegPath = INSTALLDIR + "install\\CFG.reg"; LongPathToQuote(RegPath,TRUE); LaunchAppAndWait (WINDIR ^ "Regedit.exe", "/s " + RegPath); end |
The LongPathToQuote does the actual magic
Edited by AshinSmart, 01 October 2004 - 06:00.
With regards
Ashin
Ashin
