Dialog SoftwareNotInstalled for language English (United States) built
** Error -3016: Error replacing string ID in the package
It seems to have just appeared,
I have made sure I do not have any of the following;
(Verify that all properties have valid integer values within the range of -32,768 to 32,767.
Make sure all non-nullable (cannot be left empty) fields have valid values:
This problem could be resulting when a string ID does not have a value for each supported language. In most cases, you provide a value only for the default language while authoring your setup, therefore this error can result because the new ID will have blank values for the other languages.
Check that you did not accidentally create empty rows in any tables while using Power Editor.
Make sure that you have specified an argument for each control event. )
When I remove the offending dialog, this error just appears for another dialog,
can anyone help?
thanks
Berni
