Hello, I need a little help.
In a BasicMSI-Project I use the merge modules:
Microsoft C Runtime Library 7.1
Microsoft C++ Runtime Library 7.1
MFC 7.1 (Localized)
MFC 7.1
The modules are linked to the feature FE_MFC.
The target is the Systemfolder (C:\WinNT\System32).
The modules are installed correctly.
But how can I prevent the uninstallation of the modules?
The modules should stay permanently.
Thank You
Andre'
Install merge modules - mfc71
ANo
, Dec 07 2004 12:02
Posted 08 December 2004 - 11:34
Windows Installer should handle the reference counting automatically.
If you want them to be permanent you would have to change the component attributes in the merge module (i.e. modify the modules)
