Upgrades from end-of-life versions
Even owners of very old versions, which are no longer supported and usually not eligible for upgrade pricing, can take advantage of this special offer and upgrade to the latest version. This promotion ends October 31, 2011.
What's new in InstallShield 2012
New and exclusive in InstallShield 2012 Premier
- Suite installations: A new project type to bundle multiple setups (exe, msi, msp) in a single, unified install experience with a modern UI. You can also combine 32 bit and 64 bit setups in a single package.
- Installation streaming: Only a small download is required before the end user sees the setup dialogs. The rest of the installations will be downloaded as needed.
- Installation collaboration: This add-on to develop setups in a team has been improved and requires the Premier edition. 5 licenses are already included.
- Improved 64 bit support: Dependency scanner, permissions for files, folders and registry keys, prerequisite for the 64 bit version of the Micrsosoft VSTO 2010 runtime.
- Application tagging: Mark your applications with a virtual "bar code" (ISO 19770-2 software identification tag) so that software management solutions can identify them.
- More functionality in merge module projects: IIS support, XML and text file changes.
- Automation interface supports setting the required execution level for setup.exe to indicate whether administrator permissions are required.
- New method for COM data extraction.
- Additional prerequisites: Internet Explorer 9, SQL Server 2008 R2 Native Client, Windows Identity Foundation, Microsoft VSTO 2010 Runtime (x64), Microsoft Office 2010 PIA
- Additional predefined system searches: Adobe Reader 10, Internet Explorer 9, Microsoft Office 2010, 2007 and 2003
Flexera Software also announced the end of life for InstallShield version 2009. Owners of this version can upgrade to the latest version only until November 30, 2011, but I'd recommend upgrading before October 31 to take advantage of the 20% discount offer.
InstallShield can be purchased from the InstallSite Shop at http://www.installsi...stallshield.htm
