DoInstall returns error on some of WinXP computers, on other Windows platforms it works fine.
if ( DoInstall( SRCDIR ^ SUBFOLDER_FOLIO ^ "Setup.inx", szTargetRootDir ^ SUBFOLDER_FOLIO, WAIT ) != 0 ) then
ErrorMsg( g_szCurrentSetupScript, 3507 );
endif;
Please help!!!!
DoInstall on WinXP error
galina_kor
, Dec 30 2002 18:11
Posted 30 December 2002 - 22:02
Are you using IS 6.31? Because WinXP wasn't officially supported until that release.
You could also try calling this instead:
LaunchAppAndWait( SRCDIR ^ SUBFOLDER_FOLIO ^ "Setup.exe", szTargetRootDir ^ SUBFOLDER_FOLIO, WAIT )
Posted 06 January 2003 - 21:37
| Quote (TacoBell00 @ Dec. 30 2002,21:02) |
| Are you using IS 6.31? Because WinXP wasn't officially supported until that release. You could also try calling this instead: LaunchAppAndWait( SRCDIR ^ SUBFOLDER_FOLIO ^ "Setup.exe", szTargetRootDir ^ SUBFOLDER_FOLIO, WAIT ) |
Thank you for your help. I have already done that and it works, but now I have an other error:
IKernel.exe - Application Error
'The instruction at "0x771c741a" referenced memory at "0x00164200". The memory could not be "read". Click OK to terminate the problem.'
This error caused by SdShowMsg function. It also happen only on WinXP SP1.
Posted 06 January 2003 - 22:20
Okay, but in that case, this additional item would have been better suited to a new post.
Nevertheless, I have successfully used SdShowMsg on WinXP SP1 countless times, so I doubt it's solely that. Unfortunately IKernel.exe errors are notorious for being the most difficult item to resolve, so good luck to you.
It's either something you've recently changed in your setup application or a bad system. I would therefore try a totally clean OS and see if you get the same error.
