Modifying built-in dialogs
vishwa
, Jul 13 2004 20:11
Posted 13 July 2004 - 20:11
How do I programmatically add text to a modified built-in dialog?
I tried to modify STATUSEX to show some text messages below the status bar. In the DevStudio, I went to UserInterface->Dialogs->STATUSEX. I clicked on Edit Dialog Layout, and added a multi-line text area.
Now, I want to programmatically add text to this area. Is there an API to do this?
I am not able to use CtrlSetMLEText() since it is used only for custom dialogs.
This is in conjunction to the other messages that I have posted, namely "Multiline ShowMsg" and "Installation Status Display".
Replies to any of these msgs would be of great help.
Vishwa
Posted 14 April 2005 - 08:27
Hi Vishwa,
Did u got any solution for this, if yes can you please share the details. I need such a modification in STATUSEX.
Vishnu
Posted 24 May 2005 - 22:01
Hi Vishnu,
I am sorry for such a terribly late reply...
If you are still in need of a solution,
I did a FindWindow() on the STATUSEX dialog that gives me the handle. Using that, I found the handle of the text area that I added on this dialog.
Having found the handle of the text area, I did the following
STRING statusText;
POINTER ptrStatusText ;
HWND hStatusText; // handle of the text area
statusText = "Text that should be printed on the StatusEx window";
ptrStatusText = &statusText;
SendMessage(hStatusText, WM_SETTEXT, 0, ptrStatusText);
This, though a much more complicated way than I expected, did the trick for me.
- Vishwa
STRING statusText;
- Vishwa
