Hello,
on some machines I get:
DEBUG: Error 2318: File does not exist: c:\pagefile.sys
I get it on several (not all) machines with Win 2000 and WI 2.0.2600.1183.
It happens during a minor upgrade.
With UI-sequence it accures during dialog SetupResume, if without UI-sequence it occures during CA InstallValidate.
Thanks for good ideas in advance!
Johannes
P.S. I'm NOT trying to install pagefile.sys!
DEBUG: Error 2318: c:\pagefile.sys
Johannes John
, Oct 22 2003 08:23
Posted 22 October 2003 - 09:16
| QUOTE (Johannes John @ 2003-10-22 09:23) |
| P.S. I'm NOT trying to install pagefile.sys! |
Does your setup fail because of this error? (This could simply be a debug output informing you that the file doesn't exist)
Are you low on RAM?
Posted 22 October 2003 - 12:51
Hello Stefan,
thanks for your reply!
The error terminated the run, but I have found the problem.
Because of I knew, what I had changed between the two versions, I knew where to search for the cause.
I found it in the directory table.
I had defined two new entries, each with TARGETDIR as parent und "."(point) as defaultdir. The actual values were set in the ExecuteSequence with CA35.
Now I changed the parentdir values to INSTALLDIR ( perhaps not necessary ) and the defaultdir from "." to "X".
Now the setup updates correctly.
Thanks to all.
Johannes
Thanks to all.
Johannes
Posted 14 April 2004 - 21:21
I have exactly same problem like you had when doing minor upgrade. I looked at the Directory table but could not find any undocumented MSI property like DATABASE or any invalid entry. I just migrated IS8 project to IS 9 and this error happened. Any hints to debug?
Thanks in advance!
HJ
Thanks in advance!
HJ
Posted 15 April 2004 - 06:02
Try running a validate on your msi package with installshield or orca, this might be able to point you in the right direction.
